I am trying to change the floor type - for instance, the wood finish floor. I know how to change the finish from say red oak to say pine. But my problem lies here. When I do that for each specific floor/room, it'll change the prior defined wood floor finish of every one that I have already placed, even when I select duplicate to create a new one. So, in this project, I have the dining wood floors where I changed it to a grey "Hickory wood" but when I select to create a new one, it changes the one for the Dining as well. I know it is because in the structure, it is all under the "oak flooring" finish... but how can I change the finish material to anything else when there are no other options I can use for the material that I haven't already used (because there just aren't enough options to have the number of materials i would like).
I'm not sure if any of that made sense.
here's another example. For my bathrooms, I want slate tile floors which would fall under tile, mosaic grey. I created that one. Then I created another one using the porcelain 4in tile to create my marble entryway. Now, I want to create ANOTHER type for the kitchen that is NOT marble or slate - but there are only two tile options given.
Is there a way to create another tile type that I can set for my kitchen? How do I do it?
(more pictures in replies because of the limit)
