How do i change default fascia profile thickness
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
MVE1112
4585 Aufrufe, 6 Antworten
Hi everyone,
I am trying to make the fascia in this project 20 mm thick, but i cant find the option anywhere so i googled this a bit and i read that i should edit the profile. When i look in the project browser under profiles i dont see the "default"one..
How do i change the thickness when i cant find the profile?
6 ANTWORTEN 6
Nachricht 2 von 7
Avaris.
als Antwort auf: MVE1112
Default is just a standard profile. But you can't change it.
Just create a new family profile yourself. New family > metric profile. Draw whatever profile you want and load it back in your project. You should be able to use is in your fascia.
Nachricht 3 von 7
stuart
As indicated above for sure.
Another way if you want the same profile is to go to the project browser.
Find the famlies tree and expand the list >
                 Find profiles >
                               find Profile_Fascia_Flat>
                                                  Click on one, right mouse click and duplicate>
        Right mouse click to rename>
        Double click on it again to bring up type properties and you will        see within the other section in the box the dims to change the        size.
Hope this helps.
Nachricht 4 von 7
MVE1112
als Antwort auf: stuart
In my original post I attached an image trying to do what you said. But I can't change the dimensions anywhere in the properties
Nachricht 5 von 7
Avaris.
It will load all profile families and types applicable to a fascia. You can't change it in that menu you are showing. But you need to create or a brand new family, or if you want a flat one: choose to edit the flat fascia profile and add another type.
Nachricht 6 von 7
You have to find the PROFILE in the PB and edit the size of that one (the Profile itself).
Nachricht 7 von 7
stuart
Video attached of how I do it if you just want to copy one.
