Some basics here...
I have added multiple views on a sheet.
I am having a hard time activating a view to edit inside. After getting inside, I have a hard time
getting out of it. How on earth is this done?
Also, I know how to stretch the viewport tag from the right.
I can move it up and down/ left to right, moving it along with the view.
However, how can I move the tag, independent from moving the view while grabbing it from the left side?
Gelöst! Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
1. double-click in/outside the view?
2. hover/select/drag the tag around?
This is not working for you? Not sure if I understand the issue.
I actually made this for another issue, but it fits here too :-).
Howard Munsell
Just doesn't work that way for me...maybe because I have multiple views on a sheet?
I can't get out of a view, how can I switch out?
When you're in the view turn on crop region, then double-click outside of that. Sounds like you have overlapping views, could be you're switching in between those.
1- To Activate a view inside a sheet >> left double click on it
once finished editing >> left double click on any lank area outside the view
2- to move the tag >> select it separately and move it using the mouse or arrow keys
