How did I constrain this sweep in family?
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
blank...
257 Aufrufe, 1 Antwort
Some time ago I created this garage door family, wanted to modify it now, but can't for the life of me figure out how I constrained this sweep path height.
Obviously it's somehow constrained to Rough Height parameter, but it's not placed on that reference plane, it's not locked to it, there is no dimension to it...
The only thing I can see that is locked to is the vertical reference plane in the screenshot, which controls how long it is. But what's making it go up and down with the Rough Height?
1 ANTWORT 1
Nachricht 2 von 2
Mike.FORM
als Antwort auf: blank...
Revit does this thing in sketches where if you draw a line that is close to or on a reference line (in your case 5mm away) it will default to thinking there is some relationship to that reference line and will internally lock its relative position without telling you or giving any visual indication.
