hi
i am trying to cut shipping container into half (angular cut)
so i made void extrusion (file attached)
but it doesn't work at all
any suggestions how to cut the following angular shipping container?
thanks
Gelöst! Gehe zur Lösung
Gelöst von FAIR59. Gehe zur Lösung
You cant cut nested objects. You would need to edit the nested families and cut them there. After creating void, use cut geometry tool. Then, you can cut multiple elements... Just cut one, select the void again and cut another...
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
I presume you want to use a plasma torch to cut a full-size container.
You can use a Void-family defined with [ Cut with Voids When Loaded ] to cut your container in a project.
thanks it looks great but i need to continue manipulating this shipping container , so i need it to be cut void into family, correct?
so any idea?
