So I have the standard curtain wall type occurring multiple times in a project. How can I tag them so they aren't all the same (without duplicating the type over and over again)? I noticed in a custom window tag I found that I can tag by mark which uses the entry under identity data from the properties menu allowing for different entries for one window type while the standard window tag uses the entry from the TYPE properties prompt and only one entry can be used. This is all pretty confusing as is the standard with Revit so hopefully ya'll can understand this and help. Thanks.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Thanks. I figured it out. I have to edit the label which brings up the parameters the label is based on.
@gnarkill283 wrote:
I can't just modify an already existing wall tag family? If so how. And if not, I tried creating a new wall tag family but I don't see a template for wall tags. I do see window and other tag templates.
Yes you can. Select the Tag, Edit family, select the Label, remove Type Mark, add Mark.
