How can we Show Roof fascia in Framing Plan?
5 ANTWORTEN 5
Nachricht 1 von 6
adey838FS
304 Aufrufe, 5 Antworten
I am working on a Polebarn structure. I used Fascia on the roof. But the fascia is not showing the framing plan. Is there any way it can be transformed into a structural thing and then it can be viewed in framing plan?
TIA
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: adey838FS
Fascia should show in Structural view if they are within the view range and you do not turn off the Category.
An alternative if you need to turn off the Roof > Fascia category then you can create Parts and set the structural view to Show Parts.
Nachricht 3 von 6
loboarch
You would have to add it as a structural member of some kind. If added with the fascia tool you can't just "convert" it over to a structural member that would show in a framing plan.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 4 von 6
You have me scratching my head here. Are you saying you can't figure out how to make the Roof Fascia visible in a particular View?
...is this about View Range? The Fascia is not within the View Range?
Nachricht 5 von 6
adey838FS
als Antwort auf: loboarch
so if i add it through the roof>fascia command, it wont show up in framing plan?
Nachricht 6 von 6
It will show.
