How can one draw a parabola within Revit?
13 ANTWORTEN 13
Nachricht 1 von 14
ro
829 Aufrufe, 13 Antworten
Is there a way to draw a parabola within Revit, without using Dynamo? "No" is an acceptable solution.
13 ANTWORTEN 13
Nachricht 2 von 14
Tom_Kunsman
als Antwort auf: ro
At first I was going to suggest using the spline thru points, which would be a bit tiresome as you would need to calculate the points and place a bunch of reference planes. Then I did a quick search and found these two links (one not ADSK forum, sorry)
https://forums.autodesk.com/t5/revit-architecture-forum/parabolic-curve-wall/td-p/7484025
https://forums.augi.com/showthread.php?12962-Parabolic-Curve
Nachricht 3 von 14
als Antwort auf: ro
Google "How can one draw a parabola within Revit?".  You'll get a half-dozen or more hits of tutorials.
Nachricht 4 von 14
ro
als Antwort auf: barthbradley
I tried an internet search before starting here.
I can see Dynamo solutions and I can see fragmented, laborious approximations but not how to draw a pure porabola in Revit.
Ultimately it's a formula (any) that is drawn.
Nachricht 5 von 14
als Antwort auf: ro
Nachricht 6 von 14
ro
Thanks again @barthbradley . I have done that search (I use duckduckgo but tried google for laffs). I can't see any relevant results, hence this forum post.
Nachricht 7 von 14
als Antwort auf: ro
Use Generic Model Adaptive family, add ref point and set their location using parameters (driven by a parabolic formula), then select the points and create a curve through points.
Nachricht 8 von 14
als Antwort auf: ro
I'm not following you. I posted above an actual link to a video tutorial showing how to make a parabola in Revit. Is that not satisfactory?
Nachricht 9 von 14
ro
Thanks @barthbradley . When I do that search I see a range of hyperbolic surface but not parabolas. Could be a google issue at my end.
Nachricht 10 von 14
ro
thanks @ToanDN . Sound promising. Will road test this in a couple of hours.
Nachricht 11 von 14
als Antwort auf: ro
Post a picture of the parabola-shaped construct that you are wanting to model in Revit.
Nachricht 12 von 14
ro
als Antwort auf: ro
Hi @ToanDN . This isn't too bad but, the resolution is determined by the number of points you create. And the shape is a series of splines. Is that correct?
Nachricht 13 von 14
Tom_Kunsman
als Antwort auf: ro
Yes, the resolution would be determined by the number of points. The more points the smoother the curve will get.
Nachricht 14 von 14
bogadept
Barth, every time I open a thread on the Autodesk forums, I see you making snide remarks under someone's post. You need to save the condescension for your Reddit account and work on your civility.
