I have an import from Advance Steel (via smlx, composed of folded beams) which does not show the slightly curved corner lines of the structural column, when i bring it into Revit (at least in hidden line view). The same problem occurs in plan.
Is there a visibility setting i'm missing? I can see the 2 lines in wireframe, I'd just like to see them in hidden view.
Edit: Made an error, I actually can't see them in wireframe either. Is it impossible to view subsurface edge lines in a curved surface?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You only see the line if the transition from the arc to the stretch is not smooth (not tangential). Revit native families don't show the line either.
I see.
Unfortunately the beam profile must have a tangential curve in the source program (Advance Steel).
Thank you for the illustration!
