I want to synchronize my Revit works in the cloud since I have a Microsoft Office 365 license (SharePoint and One Drive), I do not find many tutorials on the web referring to how I can synchronize my REVIT files with SharePoint. Could you support me with this question please, thank you very much !!!
you cannot synchronize Revit with Sharepoint and or OneDrive. There is no way to work directly off of either one of those service if you are wanting to use as a "network drive". You can always store your revit file as a back up to either one of those services. Your best option is to use BIM 360 or some sort of VPN to your network to work remotely or from the Cloud
@Anonymous wrote:I want to synchronize my Revit works in the cloud since I have a Microsoft Office 365 license (SharePoint and One Drive),
You will need to wait until that functionality is available if it ever happens.
@Anonymous way late to the party here, but I am doing my own research on content management using SharePoint and came across this question. It is entirely possible to host your Revit project files on SharePoint or OneDrive using the OneDrive sync functionality and saving to the synchronised folder on your local drive. However if you want to host a workshared Revit project file and work real time with other people on the same file then Autodesk locks you into BIM Collaborate Pro as their proprietary solution at a fee per person. If you want to explore a more global syncing solution for project files I recommend having a look at Lucid Link .
Hope this helps
Is it capable of hosting workshared models?
