Unfortunately, I don't know the answer but I add the picture into the text so it can be seen without downloading it.
That short segment is too short for the profile in order for the sweep to work. You have to make two separate sweeps (as you already did) and join them.
Where's you're sweep path located? Looks like is could be a continuous extrusion if the sweep path is running along the outside edge.
