How can I shade some areas to show them as out of scope?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
ahirani24
3692 Aufrufe, 6 Antworten
I have attached a rough plan layout drawing. I want to shade some rooms and put a tag in that room stating Not In Scope.
Does anyone know how I'd be able to do that?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: ahirani24
- Add project [Yes/No] parameter, name it Out of Scope, assign to Rooms and/or Spaces category
- Select all out of scope rooms and tick the box of that field in properties
- Turn on Room Color Scheme, select Out of Scope field, and give the Yes row a pattern/color you like
Nachricht 3 von 7
ahirani24
als Antwort auf: ToanDN
@ToanDN Please be a little patient with me. Currently these rooms are only spaces. Can you tell me through a step by step process as to how I could go about making these spaces as out of scope.
Nachricht 4 von 7
See steps above.  If you use Spaces instead of Rooms then assigned the Yes/No parameter to Spaces; then turn on Space Color Scheme from the same dialog (top left drop down option).
Nachricht 5 von 7
ahirani24
@ToanDN I just used region under annotate to solve the hatching problem. Thanks for your help. I'm sorry I can't understand what you are trying to state. This is really frustrating for me and I accept I am a total novice at Revit.
Nachricht 6 von 7
chughes
Alternately, depending on how simple you would like to keep it, use a masking filled region (of whatever color is preferred) on the NIS spaces and set the Filled Region ByElement transparency setting to 25% or whatever makes you happy.  This is a graphic representation solution, not a BIM solution that @ToanDN is proposing, though.
2021-08-23 15_55_32-2021-02-23 - 20280 - AXLER GARAGE - Bluebeam Revu x64.jpg2021-08-23 16_00_09-Autodesk Revit 2021.1.2 - [Axler Garage.rvt - Elevation_ EAST - NEW].jpg
Nachricht 7 von 7
als Antwort auf: chughes
This is a perfectly fine, if not the best, solution for what you are showing.
@ahirani24 see this link for information on Color Schemes.  there are video tutorials I think.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2021/EN...
