how can I save a project in older versions?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
lina_riquelme2201
226 Aufrufe, 4 Antworten
I have revit 2025, but i want save it in 2024, due to problems with 2025 version (it closes suddenly) so I have download the older version but it cant open my project. what should I do?
Beschriftungen (2)
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: lina_riquelme2201
@lina_riquelme2201
You can’t back save to older version. Your best bet is to export as IFC … when you link that into 2024 it will generate a .ifc.rvt  file which you can use.
do u have all the updates installed… maybe u can try fix the crashing issue . Check your other post and upload the Journals (See Link Below)
the program closes suddenly - Autodesk Community
Nachricht 3 von 5
handjonathan
Hi @lina_riquelme2201
Thanks a lot for posting your question to the forums!   Has the solution suggested by @RDAOU helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 4 von 5
RSomppi
What is causing the crashes?
Do you get any messages as it is crashing?
Does it happen in all files?
Reinstalling Revit may fixe the crashes.
If not, maybe there is something wrong with the model.
Nachricht 5 von 5
HVAC-Novice
You should resolve the crashing issues. Did you install the latest SP? R2025.4?
https://revitlink.blogspot.com/2017/05/why-is-revit-not-backwards-compatible.html
Revit version: R2025.4
