hi everyone ! i'm a student and started to learn REVIT for a few days , i don't know why i can't render my drawing . in the picture below , after finish my drawing , i can;t render it . is it relating to the REVIT version or there are something wrong to my drawing
thanks
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
strange, delete the existing 3D view and create a new one and see if helps. thanks
check also in your properties > view template > set to none and see if helps. thanks
thanks for your help , i know what happen to my REVIT , it is because i didn't download library so i can't render . now i just need to download it
also , do you know how to download it ?
you can refer to these LINK and LINK and see if helps. thanks
