Could someone help me remove the rows with red circles from my schedule table?
I have attached a screenshot.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
@ahirani24 wrote:
@ToanDN this would help if I have both the projects opened in one instance. Is there a way, I could copy the schedule table to the desktop and then insert it to a new project - mainly cause both the projects would be open in different instances.
No. You need to open both projects in the same Revit session in order to copy paste.
If not, then open the other project and Insert > Insert from File > Insert Views from File > then navigate to your original model and choose the schedule to insert.
