How can I "heal" wall gaps?
5 ANTWORTEN 5
Nachricht 1 von 6
svalen
729 Aufrufe, 5 Antworten
How can I "heal" wall gaps like these? Trim is not working,   or even redrawing a wall in the same location.heal wall.JPG
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: svalen
Typically see this in Phasing. Do you have a Wall there in another Phase?
Can you Disallow Join and drag wall end to meet other and then Join Geometry to hide visible edges?
You can also use the Wall Join Tool on the Modify Tab to cycle through Joins.
Nachricht 3 von 6
Disallow join the lower vertical wall, drag it to fill the gap, then join geometry all three walls. Alternately, turn on demolition and disjoin the existing/demolished wall that occupies that gap.
Nachricht 4 von 6
_Vijay
You better model as pet construction method.slab should be extended.
Nachricht 5 von 6
svalen
als Antwort auf: barthbradley
I don't have a wall join option,  really stumped with this one... I attached the file...
Nachricht 6 von 6
hmunsell
you have a New Construction phase wall there that is hidden in view.
Howard Munsell
