How can i put multiple Projects on a sheet?
9 ANTWORTEN 9
Nachricht 1 von 10
1134 Aufrufe, 9 Antworten
I have multiple rvt. projects that I wish to put in one single sheet, I have tried to insert them from file, etc. I do not want to export the file into another software. If I can get ideas tips or in a direction to head that would be great.
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Anonymous
Do you mean bringing in all the sheets from multiple projects to become sheets in one project?
Nachricht 3 von 10
als Antwort auf: ToanDN
Yes that is correct.
Nachricht 4 von 10
Only works for sheets with drafting views. For sheets with other views such as plans, elevations, etc... You need to recreate them.
Nachricht 5 von 10
thank you.
Nachricht 6 von 10
Out of curiosity, what is the other software you are referring to your first post?  Do you mean you found a way to do it, but it would require other software?
Nachricht 7 von 10
ocalemre
I saw that, the problem was not solved.Is there a new idea? I'm still wondering.
Nachricht 8 von 10
laura_bruch
If it's just for printing, can you not use the snipping tool to take a screenshot, and link it into the sheet as an image? If you can't in sheet view you can definitely do it in drafting view.
Nachricht 9 von 10
anze.kumar
als Antwort auf: laura_bruch
In sheets you usually have a drawing that needs to be a "vector" file, so it can be scaled appropriately and to make every View a Drafting View, would be a lot of work..
.. maybe I am missing something but would be glad to hear if anyone also have a solution to this?
Nachricht 10 von 10
mhiserZFHXS
als Antwort auf: anze.kumar
Correct. This would not be a good workflow.
Again, you can copy over drafting views from another model. It makes sense that you can't copy over model views because they contain elements from that model, not the model you are trying to paste to.
If you've drawn detail items in a model view for enlarged sections or details or something, and want to copy that into a different project because you have a similar condition, you can copy and paste the elements themselves (not the view) to the new project if you have them both open in the same session. Or you could copy and paste them into a drafting view in the original project, and then paste that drafting view into the new project.
