10:22 AM
My house is not at 90 degree angle in Revit,it is at some 30 degree angle, so I had very difficult time while doing the dimensions. Now I have manually placed all the lights in my ceiling view because I could not use array command. They are not looking good as they are not at equal distance. I also tried to place grids in my first floor ceiling plan view so that I could place my ceiling lights on grids intersection but now I cannot find a way to make equal distance between grids which could have been easily done if my house was drawn at a proper angle in revit by using aligned measuring tool. Revit is not recognizing aligned tool now.What can I do.
