I sometimes want to override the values of dimension texts with some other values ( which may be useful in some cases due to inaccuracy of recorded site plan datas with real world values. In which i may have to show the recorded values rather than the real site values) . Is there a way to do it without having to use the text command and replacing it manually??
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
It’s only manual as i know
double click on the dims text and override it Or use suffix or prefix
also there is an option called alternative dims in type prop maybe useful for you
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
thanks for the answer but double clicking on the dim text wont allow you to change it numerically , it allows only replacing with letters. Alternative dims only shows alternative units
