How can I organize the Project Information Parameters in alphabetical order?
I created some shared parameters, but when I put in the project parameters, they didn't stay in order.
What I can do?
They are ordered based on the order you added them, not alphabetically.
It has always been a thorn in my side as well -- reorganizing Shared Parameters.
If you have a Family already loaded into the Project, and you edit the Family to change the Parameter order and reload the Family into the Project, the old Parameter order remains unchanged.
What you have to do to correct this is to load into the Project Parameters the exact same Shared Parameters that are in the Family, in the order you want into the Project Parameters.  Afterwards, reload the Family and the Families Parameters will then be in the same order as the Project Parameters.  Afterwards, you can delete all the Shared Parameters from the Project Parameters.
A pain in the buttocks.
pieterschiettecatte
There's no way to reorder Project Parameters today but there's a popular revit idea about it that you might want to consider voting on: https://forums.autodesk.com/t5/revit-ideas/sort-project-parameters-like-family-parameters/idi-p/6589...
