How can I only export the latest revision on Revit PDF Export?
2 ANTWORTEN 2
Nachricht 1 von 3
RC_RVT
625 Aufrufe, 2 Antworten
Not sure if this is the place to post this. If it isn't, please direct me elsewhere.
Is there a way for Revit PDF export to only export the latest revision of drawings automatically?
For example, I have issued revision C1 and now have a C2 revision, but it isn't all of the sheets. Rather than go through and select only the sheets which are C2 manually, is there a way I can automate this?
If automation isn't possible, is there a way I can filter the sheets on the PDF exports by revision number so that I only have to "Select All", rather than having to manually tick the sheets I want to print?
Sorry if this doesn't make sense. For context, I've attached a screenshot of the PDF export selection box, which is where I do it manually at the moment.
If this works, please mark it as an accepted solution. This helps make the forum a better place.
2 ANTWORTEN 2
Nachricht 2 von 3
RC_RVT
als Antwort auf: RC_RVT
I forgot to mention that I'm using Revit LT 2022
Nachricht 3 von 3
Not automatically.
Create a sheet index and filter by current revision = c2. Note the sheets listed. Export to PDF, choose only sheets listed above and save as a set to export or print.
With full Revit, you could install PyRevit to create a set using any given revision then export or print the set. Alas you are using LT.
