HOW CAN I MAKE THIS SWEEP FOLLOW THE SLOPE OF THE WALL?
1 ANTWORT 1
Nachricht 1 von 2
jsrlrpc
164 Aufrufe, 1 Antwort
SWEEP.pngI want the sweep on the middle wall to follow the wall as I have drawn in pink. How can this be done?
1 ANTWORT 1
Nachricht 2 von 2
jay_colcombe
als Antwort auf: jsrlrpc
As you may have found out wall sweeps can only be horizontal or vertical, they can't slope.
You need to use a "Model-in-Place" family for the sweep.
Select "Model-in-Place" choose "Sweep" and then choose "Pick 3D Edges". Select the sloping wall, load or draw the profile, and you're done.
Another way to create profiles along an angle is to use a workaround to create a Roof Fascia on a Model line
Please a Model Line on the Slope Edge using a Reference Plane and when using the Roof Facia Tool pick the Model Line
Jay Colcombe
Autodesk Certified Instructor
