How can i make .rfa file? I wan to make it for my project so how?
SP-PRAJAPATI
Message 1 of 8
SP-PRAJAPATI
I M using Revit 2018 Now i want to make some family products too! how can i do this? .rfa file
Replies (7)
Message 2 of 8
Ilic.Andrej
You asked something nobody has before, because you covered thousands of questions with only just one. Thus, to answer your question, one must do a deep research. Your question trembles the hearts of teachers, because it reminds them of the beginning of their journey when they spent time reading hundreds of articles. Can you feel it? The spirits of the dead pioneers are not happy, because they see that you also have the spirit of a pioneer. You prove it with your ultimate question. Now, you must take the journey into the unknown and find the answer yourself! Maybe this is the link that will help you start, but be warned! The path is blurry! You must pay attention to all the clues. Those may lead you to other questions, but try not to forget the first one! Who knows when the answer to it will be revealed?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 3 of 8
The stock default Project Template that you use to start a New Project has a bunch of Families already loaded into it.  Additional content is found in your Library and loaded into your Project via "Load Family" on the "Insert" Tab.
Message 4 of 8
SP-PRAJAPATI
But I want to make it my own! How can I??
Message 5 of 8
Google it.
Message 6 of 8
SP-PRAJAPATI
But you can tell me that which software I've to use for this! I can learn
myself! Just tell me man!
Message 7 of 8
File > New > Family > Select a family template to start from > Draw something > Save.
Message 8 of 8
Keywords: Revit, Family, Tutorials, Beginner.
Or, maybe just type "How to build a Revit Family" into the Google search bar and see what pops up.
