How can I insert a bigger mullion Jamb for this door?
mochoaN23TG
mochoaN23TG
I need to create a 6" jamb for the door. How can I go about doing that without changing all the other mullions?
Samantha-G
Hi @mochoaN23TG
You will just need to have the correct mullion type loaded.  The problem you may have is if the jamb is too large it may, cause the door to error out.
Sometimes people will create entire "walls" that will have everything included the way they want it.  Such as the correct doors and extrusions for the different types of mullions, but that does take a lot of time to put together.
Sam G, CM-BIM
Revit Certified Professional
mochoaN23TG
I have the correct mullion family loaded, what options would I need to mess with to insert the family? Every time I seem to change that mullion, all the vertical mullions change as well.
Samantha-G
Hover over the correct mullion, and press tab that will let you cycle through the selections.  This will allow you to choose the correct one.
Sam G, CM-BIM
TAB-Select the Mullion, unpin it, pick a new type from the Properties Preview Selector.
