Anyone know how can I hide this??
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
... hi @Anonymous
... yes , it is a well known issue with the 2020.2 update
... goto VG
... site
... and un-check the internal origin
… this thread has been around a lot since the update
… sometimes existing 2020 files are seeing the internal origin category being turned on in 2020.2
… sometimes upgraded projects from prior to 2020 versions are not affected
... it is a new addition to the REVIT layout in 2020.2 internal origin point
… top-5-best-new-features-in-revit-2020.2
…. they don’t print… so no problem … just get use to those
… also take a look at this forum discussion / explanation
… changing-internal-origin-default
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
