How can I get rid of wrinkled view ?
3 ANTWORTEN 3
Nachricht 1 von 4
dcnkzr
303 Aufrufe, 3 Antworten
Hi Everbody , I have splitted some areas of my topography using "split face" then I exported splitted face as dwg and I 've created mass from that dwg and I 've created roof from that mass.Everything worked nicely but I got that wrinkled view.Hoe I can get rid of it
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: dcnkzr
Turn off the Mass. Plus, you've created roof by mass faces. It's not draped over the mass. You will see edges.
Nachricht 3 von 4
dcnkzr
als Antwort auf: barthbradley
I've touhgt that but I couldn't find it.I select everything but there is no mass element
Nachricht 4 von 4
If you want more of a free-form roof, model it in a mass template or with your massing tools inside In-Place Mass. You can use your imported DWG -- or the original Toposurface it was created from  -- as a reference in shaping the mass.
