How can I get a good insulation take off? Do I model insulation?
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
svalente9GJKH
290 Aufrufe, 1 Antwort
I see the Revit comes with a material called structure joists, with fiberglass insulation.
Is this what you should use if you want to be able to have material take of show insulation?
You wouldn't model insulation inside of a wood stud layer would you?
Also, has anyone ever had any luck adding a cut insulation hatch to a stud wall?
1 ANTWORT 1
Nachricht 2 von 2
Martijn.Pater
als Antwort auf: svalente9GJKH
How about some images... what are you after exactly? edit: material take off takes off the material applied, so no, you should not use this but you could if that's the material you're looking to use...
edit2: aw I think I got it, but I guess you could use curtain walls instead...
