How can I export only the core portion of my walls? I don't want to export gypsum board or furring or exterior finish (See image).
Thanks for your guidance!
John
You cant by default....
couple options if you absolutely need to do it:
Parts:
Copy Monitor: https://autode.sk/3kVdtrr
Trace:
https://forums.autodesk.com/t5/revit-ideas/wall-structural-component/idc-p/9288195#M30895
https://forums.autodesk.com/t5/revit-ideas/wall-detail-level/idc-p/9307468#M31032
Howard Munsell
Sounds like you are repurposing an oldie but goodie Bob Mackay trick...
https://bdmackeyconsulting.com/show-only-core-of-walls/
@barthbradley LOL, that's funny, I've actually never seen that Bob Mackay trick before. figures someone else figured it out too, and back in 2012. i figured it out a while back when one my structural engineer was inquiring about the same issue.
Howard Munsell
Why not duplicate the wall type and delete the finishes and shear? Quickly export and then hit ctr z to undo the change.
Seems like an easier and quicker solution. You would need to of course lock dimensions at the core face of the framing. The walls would need to be drawn with the location line set to exterior core. Might not be easier if you have to redraw the walls with the proper location lines.
@barthbradley Using the previous method, will I then be able to export a 3D dwg file with just the cores?
