How can I duplicate a Revision name in sheet issue/ revision box
Khashayar.Saffarifardkhouzani
Message 1 of 9
I am looking for a way to duplicate the revision name in revision box ( for instance having 2 Rev A with different description for each and then allocate each to a specific page. Generally Revit doesn't let to use a number or alphabet that has been used before .
Replies (8)
Message 2 of 9
d.ahmed.LW
Hi @Khashayar.Saffarifardkhouzani
i think what you are looking for is this option "Per Sheet" while setting your Revisions.
More details: Video: Revision Numbering By Project and By Sheet | Revit LT 2020 | Autodesk Knowledge Network
Message 3 of 9
khashayar.saffari
Observer
Observer
IMG_20230218_190415_996.jpgI want it all in project not sheet. Have look at attached photo.
Message 4 of 9
Create two different custom lettering systems so that you can have the same revision number and revision description, but on different systems.
Message 5 of 9
khashayar.saffari
Observer
Observer
Can you explain more please. how can I make custom lettering sys?
Message 6 of 9
Which version are you using?
Message 7 of 9
khashayar.saffari
Observer
Observer
2021
Message 8 of 9
It only works in 2022 onward. Sorry.
Message 9 of 9
RobDraw
It sounds like you might be wanting to use the description to describe the changes somehow? That's not the way revision schedules should work. Revision 2A should have the same description throughout the project. Any additional descriptions should go with the accompanying documentation.
Rob
