How can i draw curved wall on sloped slab?
25 ANTWORTEN 25
GELÖST
Nachricht 1 von 26
3436 Aufrufe, 25 Antworten
25 ANTWORTEN 25
Nachricht 2 von 26
als Antwort auf: Anonymous
Hi Solari_1
This is an interesting problem, but I found a work around you could use. Please refer to the attachment provided. I hope this helps you!!
Nachricht 3 von 26
There's several approaches. Probably quickest and easiest would be to draw the wall on the lowest Ref. Level and define it's Top Constraint as the highest Ref. Level (the same top constraint defined for the other walls) - and then use the Attach Top/Base tool to attach the Base of the wall to the floor.
Nachricht 4 von 26
PijPiwo
als Antwort auf: barthbradley
The wall in question will not attach to the angled floor when joined with the other walls, but will attach to the ref. plane drawn parallel to the angled floor.
Nachricht 5 von 26
als Antwort auf: PijPiwo
But, there is no wall attached to other walls in the OP's screenshot, so I don't understand your point. The OP is asking how to place a wall on the sloped floor. Doing it the way I described will work. There are several other ways to do it well.
Nachricht 6 von 26
PijPiwo
There are no walls, probably because the OP couldn’t do it the way he/she wanted to - it’s my assumption though.
@Anonymous, to continue with my assumption that you want a continuous wall all around, another option would be to model the floor as one piece and use Modify Sub Elements to get desired heights. All walls will attach to this floor with no problems. Just be aware that Modify Sub Elements option will change the thickness of the angled part of the floor - steeper angle, bigger distortion.
Cutting the bottom of the wall with a void swept blend will work too if Mod. Sub Elem. is not an option.
Nachricht 7 von 26
constantin.stroescu
Maybe I miss something here , but it works if you
  • first make a rectangular floor slab, edit it with Modify Subelements, then Attach Top/Base with Attach Base works for floors. (first screencast)
  • If you want the floor to be exactly on the wall contour then , you can use  Void Floor to Cut the first floor (second screencast)
https://knowledge.autodesk.com/community/screencast/acb5a045-bc47-4fe4-9b70-4eb71791ec0a
https://knowledge.autodesk.com/community/screencast/dd4f1e8c-bfe5-4f62-a1d5-19edaa264dfb
Constantin Stroescu
Nachricht 8 von 26
This is correct and a very simple solution, IMHO.
Nachricht 9 von 26
FGPerraudin
als Antwort auf: ToanDN
hi @Anonymous,
Make sure as well that the wall you want to attach overlaps your slab in plan view entirely.... just to make sure!
Other question, did you use the slope arrow tool or su-elements for the creation of your slope?
François
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 10 von 26
als Antwort auf: FGPerraudin
slope arrow to make the floor slope
Nachricht 11 von 26
Sahay_R
Can a reference plane be created along the sloped slab and used to cut the wall?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Tags (1)
Nachricht 12 von 26
FGPerraudin
re-hi @Anonymous,
I have tried it on my computer as well and I don't get what is going wrong with your model.
OK, so here is a screenshot just to be sure that you do the right things:
First of all, select your wall.
Are you sure you click on the (1) button?
Then that you check bottom attachment (2)
And then pick the floor you want to attach your wall to (3)?
PS: you can attach your wall to several floors as shown on my picture
François
Nachricht 13 von 26
Nachricht 14 von 26
@FGPerraudin
Try it when you have a string of more than one walls.
Nachricht 15 von 26
FGPerraudin
Hi @ToanDN,
You were right, I have just had some tryouts with a string of walls.
My conclusion is that Revit Cannot attach base of wall if the handle of the wall rests onto a slab edge.
Basically Revit cannot calculate the junction of the wall if its skatch line lies onto one surface and its thickness onto another one (try it it is quite interesting...)
But it works if they do not!
1 works (wall handle on a surface)
2 doesn't (wall handle on the edge)
Very interesting to know for further notice!
Cheers,
François
Nachricht 16 von 26
thank you so much
Nachricht 17 von 26
Actually, the two "instep" side walls will join to the floor using the Attach Top/Base method, just as I described. The walls are joined as well; however, because there is a change in direction at the top and bottom of the ramp, there is a "hinge" in the walls - just as there would be in the as-built condition.
Nachricht 18 von 26
@barthbradley
Come on, the walls are clearly not joining properly no matter how you paint them to be:
And why accept hinges when you can do without, not by one, but multiple approaches which are relatively simple?
Nachricht 19 von 26
Gimme a break, Toan.
My exhibit only demonstrates that the wall CAN BE attached to the floor. Exactly as I said - twice. I also said the there are other ways to do it – twice.
I’m not advocating an certain approach; just saying that it can be done this way. It appears not everyone was not able to.
And, when I said “join”, I qualified it by saying there is a “hinge” – which actually would mimic the as-built framing.
Obviously, if you are designing circuit boards; this 1/32” gap wouldn’t be an acceptable tolerance. But, in building construction; printed on paper at ¼” per foot – it ain’t getting red-lined in plan check! I assure you.
Nachricht 20 von 26
...but, if it makes you feel better Toan; I thought you had this one nailed for best Solution. I'd have chose it, but unfortunately the OP didn't. Better luck next time.
