How can i do this form for entrance?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
karimovazumrud05
312 Aufrufe, 4 Antworten
Hello, i would like to give this form in my project for entrance but i dont know how to
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: karimovazumrud05
Curved walls with a voice to cut them, roof, beams and columns supporting the roof.
Nachricht 3 von 5
karimovazumrud05
als Antwort auf: ToanDN
is there any tutorial to how to do it, for such forms ?
Nachricht 4 von 5
Corsten.Au
Hello
You can model those in parts, floor, walls, walls with edit profile etc.
If you can figure out inplace massing, then you can model walls by face and create something like that.
In massing, if you change the mass ( design ) you can update the walls to follow that mass..
I tried a bit and see if that works for you...
Create in place mass, edit the edges as per your designCreate in place mass, edit the edges as per your designcreate multiple adjusting the internal designcreate multiple adjusting the internal designuse wall by face and create 3d geometryuse wall by face and create 3d geometryafter creating all the walls by face...staircase should be easy I guess.after creating all the walls by face...staircase should be easy I guess.you can change the mass to adjust and update the walls accordingly.you can change the mass to adjust and update the walls accordingly.
Corsten
Building Designer
Nachricht 5 von 5
karimovazumrud05
als Antwort auf: Corsten.Au
thank you very much!! i couldn't find a proper way of doing it, this really saved me a lot of time
