How can I delete a single wall type from my project? I don't want to purge. I only want to get rid of 1 wall type that folks keep accidentally using.
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
In the project browser right click on the wall type you want to delete and select delete.
Louis
Please mention Revit version, especially when uploading Revit files.
Louis, Thanks
Where are the borders listed similarly? Folks load in the wrong ones and then people making new sheets don't know which one to use.
Nardo
Title blocks are also families and found under the category "Annotation Symbols" in the project browser.
Louis
If you can't delete type by right-clicking in Project browser, make sure, that this type is not used somewhere in the project and try to use purge-tool.
Also, you can't delete the last remaining type of a system family (as I remember, wall is the system family).
I'm having a similar issue, so how to delete a compound wall's layer/finish?
