How can I create such a window? help
15 ANTWORTEN 15
GELÖST
Nachricht 1 von 16
ahmetarmagan135
1682 Aufrufe, 15 Antworten
Beschriftungen (2)
15 ANTWORTEN 15
Nachricht 2 von 16
RDAOU
als Antwort auf: ahmetarmagan135
@ahmetarmagan135
You can create a mass >> divided into a custom pattern >> and use curtain system
Nachricht 3 von 16
ahmetarmagan135
als Antwort auf: RDAOU
I don't understand how to draw massing lines. Can you send an image for me? step by step
Nachricht 4 von 16
RDAOU
@ahmetarmagan135
1. make a vertical surface
2. Place a ref plane parallel to it call it say (Canvas)
3. draw reference line to make the pattern you want on the Canvas plane
4. Divide the surface u created in 1 and switch off the grids
5. Use intersects and select the ref line then click finish
I remember I have a screencast on this let me look it up and upload
Nachricht 5 von 16
ahmetarmagan135
ohh thank you very very much. so how do i turn these lines into a curtain wall?
Nachricht 6 von 16
RDAOU
@ahmetarmagan135 .
Hmmm...several ways, Ideally you would/could use use adaptive components
If this is too much and you cannot work with adaptive components...An easier way would be to model each wall span as a Curtain Panel and sweep/extrude the mullions as part of the Curtain Panel family. The use those panels on a curtain wall without the system mullions
Nachricht 7 von 16
ahmetarmagan135
do you have a video about it? I searched a lot but couldn't find
Nachricht 8 von 16
syman2000
It is doable with curtainwall. You have to understand how to host Curtainwall with nested curtainwall to achieve the effect you want.
Nachricht 9 von 16
ahmetarmagan135
als Antwort auf: syman2000
wonderful. this is exactly what i want. I am using revit 2017, I could not open the file. Is there a video that can help?
Nachricht 10 von 16
RDAOU
@syman2000
Creative and practical, but are you aware that nested curtain walls do not function well with phasing?
Nachricht 11 von 16
syman2000
It should be easy to setup. All you need to do is change the angle of grid.
Next you select part of the curtainwall panel with curtainwall and then you add grids
@RDAOUi am aware of the shortcoming with curtainwall
Nachricht 12 von 16
ahmetarmagan135
This way I can only use one angle. but i need more than one angle
Nachricht 13 von 16
ahmetarmagan135
i am waiting for help
Nachricht 14 von 16
Nachricht 15 von 16
syman2000
Yup...this is why you select the panel and switch it to curtainwall. This way you have panel that can create new panel with new angle. See sample for 2017 version. It should let you understand how I was able to achieve multi-angle mullion. Every time you want change angle, you have to swap panel with curtainwall and then add new grid with angle.
Nachricht 16 von 16
RDAOU
@ahmetarmagan135
The pattern based and/or adaptive component method which @ToanDN casted remains the better option...here below is a simple method using a normal curtain wall panel. This method requires that you model the Wall to same same ratio/proportion (otherwise you will need to add more planes and parameters to constrain the irregular grid)
You should be able now with all the above methods to model that curtain wall
