How can I create parametric OAH with radial array cables?
0 ANTWORTEN 0
Nachricht 1 von 1
ml-double-e
130 Aufrufe, 0 Antworten
Hello all. Thank you for taking the time to read and potentially help.
I am very new to Revit. In the attached file, I am having trouble with my mounting cable OAH parameter & the radial array.
If I constrain the cables to the reference planes in order to get them parametric for OAH, the radial array radius parameter does not meet constraints. Likewise the other way around. I am currently trying to nest the cables as a separate family but cannot figure out how to get them to function correctly that way either.
Any help would be VERY much appreciated, thank you.
0 ANTWORTEN 0
