How can i attach a curved curtain wall to a sloped roof?
chase.conn72
chase.conn72
I have a curtain wall that I need to attach to a slightly sloped roof, but I can't figure out how to attach it.
Alan.johnson1970
I would just select the curved section of curtain wall and use attach top/base and then select the roof.
AJ.
Alan.johnson1970
Make sure you have some overhang or the roof follows the curve of the curtain wall exact
AJ.
...or go to Elevation View, draw a Ref. Plane along the underside of the Roof, and then use Wall's Attach Top/Base tool and select the Ref. Plane as the Target.  Bada Bing!
