Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Two ways -
1) to PAINT each part with a different material (which may not be a global solution for the family you are creating)
2) go into Manage >> Object Styles. Create Sub-Categories. You can then create sub-categories in Electrical Equipment or Electrical Fixtures for components and give them different colors and materials
Hi @Anonymous
Option 1
My first choice would be to assign different material Parameters to the different components of the the Family...Select/Edit the Family
to go to Family Editor
Option 2
Paint can also be applied in Family Editor as a Material and assigned with a Parameter (usefull when you want to assign several material/colors to the same component - Example: Front face Yellow and Edges Red) - To do so, Select/Edit the Family to go to Family Editor
Now your paint has associated with a type parameter and has a global impact on all instances of the same type
Option 3
Using subcategories - can be powerful yet may get crubersome and had to manage. I personally try to avoid using subcategories for material control. Especially when some families may contain shared nested components of different categories. Also in Family Editor -
