I have linked several supplied models in my model of the techniques. Now there are a lot of 'dummy' elements in the architecture model that I should take out (eg the columns that are still present in the architect's model, but whose correct columns are in the stability model).
The architect's model is structured in such a way that parameters have been added that indicate whether it is a dummy element or not. It is this parameter that I would like to use in my model so that I can filter out the dummy elements from the link. But of course the parameters from the linked models are not visible when I want to create a filter.
Is there a solution for this?
Gelöst! Gehe zur Lösung
By default, the view filters apply to links also. What is the parameter that was used?
Yes I know that filters also work on linked models. The problem is that i can't create the filter that i want to use because i can't use the parameter from the linked model.
It is a self-created parameter by the architect, named 'JTBC_C_TX_Wijziging'. I can only choose between the standard parameters from my model or my own created parameters.
You will need the same shared parameter in your project to be able to control it. Select the shared parameter in your project parameters to make it available.
Hi Tim,
how do I "select the shared parameter" from the linked project, to get into mine?
