Clip the edge with a In-Place Void cut and then place a Wall Type that contains only the Finish Layers along the clip angle. Then use Join Geometry.
Several ways:
- add a vertical wall sweep with a custom profile
- model an in place void and cut the wall with it
- crate an opening family with voids that cut the wall to that shape (if it occurs at multiple openings)
Here is an example of using a wall sweep with a custom profile. Your profile should be half of it and placed right at the end of the wall.
Go to Plan View. Activate Model In-Place (Architecture tab). Choose Void Extrusion and sketch the Profile. Finish and adjust the Extrusion Start/End Parameter values as necessary. Now use Cut Geometry tool to cut the Wall with the Void Extrusion. Close out of Model In-Place when done.
Just to be clear: you need to cut the wall with the void BEFORE exiting Model In-Place.
Note: this only works on system families. Is the wall a system family wall?
