How can I add an additional unit of measurement in the same project
2 ANTWORTEN 2
Nachricht 1 von 3
607 Aufrufe, 2 Antworten
Hi everyone,
Hope everyone is safe and sound.
My project unit is in meter, and my window sill tag shows the measrement in meter.
How can I keep my project unit in meter but change the tag unit to centimeter?
Thanks in advanced.
Regards
2 ANTWORTEN 2
Nachricht 2 von 3
martijn_pater
als Antwort auf: Anonymous
You can create/adjust a dimension type to reflect alternate units. edit: same for spot elevations i.e.
Alternate unitsAlternate units
Nachricht 3 von 3
hmunsell
if you just want the tag to read in centimetres,
  • edit the window tag family
  • pick the parameter reporting the dimension
  • pick the Edit Parameter Unit format option below the parameter window
  • uncheck use project settings
  • set your own settings.
Howard Munsell
