How can I add 135 degree hook in stirrup?
5 ANTWORTEN 5
Nachricht 1 von 6
1620 Aufrufe, 5 Antworten
How can I add 135 degree hook in stirrup? please help.
5 ANTWORTEN 5
Nachricht 2 von 6
MostafaElashmawy
als Antwort auf: Anonymous
This topic should be asked at Revit Structure forum.
However, Please load attached family into your model. it have the required hook nested inside.
Mostafa Elashmawy
Nachricht 3 von 6
Corsten.Au
Can you find that hook in families ( just right click families and search )
edit that family ( hook 180) with new angle , rename it ( Hook 135 ) and load .
it should be available in those option after loading .
Corsten
Building Designer
Nachricht 4 von 6
als Antwort auf: MostafaElashmawy
I loaded the file but problem is not solved till now, its showing only 90 degree & 180 degree hook.
Nachricht 5 von 6
Hi
I am experiencing the same.
A few weeks ago, I had the 135 seismic hook option in my drop down (Hook At Start and End), but now I see that it is not showing, although it is in the Type Properties. I don't suppose that it is a family issue, as I had access to this hook previously and it shows in the Type Properties. Did you manage to solve your problem?
Nachricht 6 von 6
try this: under properties browser, find the hook family (structural rebar --> rebar hook --> standard hook) right click, type properties and either create a new hook or change the 135 degree type properties to standard.
