How bring back Internal Origin to 0.0.0 ?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
u_pekli
1251 Aufrufe, 2 Antworten
My internal origin is at N/S -1574 and +8 elevation (on my template).
How to get back to 0.0.0 ?
Everytime i draw a toposurface, my points are at 0.00, but they are in fact at +8 !!! Crazy...
I've spend hours on internet, cannot find any topic about this.
Thank you.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: u_pekli
First of all, the Project Base Point is showing Coordinates relative to the Survey Point Origin.
Second, Toposuface Internal Points (those placed in Sketch Mode) are relative to the the Internal Origin of the Project -- which is always at 0,0,0 and cannot be changed.
Typical workflow is too create Toposurface and then go to Elevation View and raise it to where it needs to sit in relationship to the Project's Building.
How are your creating your Toposurface?
Nachricht 3 von 3
u_pekli
als Antwort auf: barthbradley
Thank you for remembering the basics, i've found my mistake... I've set the 0 of my basement floor elevation to +8 !
Then the survey point was always at +8.
When you right clic on project base point, you can replace to "internal origin", but it's just the survey point. Confusing...
