I'm unsure whether I need Revit Lt or Full, and would appreciate some guidance on whether the following are possible within Revit LT:-
- Is it possible to create separate models for different house types, and then link them into a separate masterplan model (multiple times for each, with different positions/orientations/handings)?
- Is there differences in the topography capabilities? Can point levels be placed and manipulated on topography in LT?
- Similar question for floors: Can point levels be adjusted to create ramps, or manipulate floor levels (falls to hard landscaping, for example);
- Are the stair edit by sketch functions available in LT?
Gelöst! Gehe zur Lösung
Gelöst von loboarch. Gehe zur Lösung
Everything except you 3rd point of wanting to "shape edit" floor elements is possible in Revit LT.
