Can anyone explain to me why all of my wall hosted objects are buried into the wall rather than on the surface where they should be?
Note all of the plumbing fixtures in the attachment as well as the Rinnai Tankless water heater that's half buried in the wall.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
It's not clear to me from that view that they are buried in the wall. Did you check 3D View to verify that they are indeed recessed into the host wall?
You're welcome to post your file here if you want us to inspect it.
They are definitely submerged in the walls in every view. It would logically have to be something to do with the wall style since multiple different plumbing fixtures are having this issue.
The dropbox link in my last reply should be the revit file.
They are not associated. Select, press Edit Work Plane=>Pick a Plane and then pick the host wall. Bada bing.
Thank You again sir. I wish I knew why they didn't host to the walls in the first place. I removed and re-inserted them at least a dozen times. Happy New Year!
