Hosted Family Issues
1 ANTWORT 1
Nachricht 1 von 2
172 Aufrufe, 1 Antwort
Is there a way to group several hosted family / components and copy them into a new revit file or existing revit file with a different layout?
And modify it? (e.g. rotate the hosted family) since an error message came up when I attempted on rotating a hosted family.
1 ANTWORT 1
Nachricht 2 von 2
Sahay_R
als Antwort auf: Anonymous
Are you trying to copy families from one project to another? In that case, select the families, group them, Saveas >> Library and you will be able to save them to a new RVT.
The other method - open the families, and the destination RVTs in the same Revit session. In the family - click Load into Project, and in the dialog box that comes up select the RVTs you want it to go in.
To rotate families - take a look at these links -
https://forums.autodesk.com/t5/revit-architecture-forum/rotate-error-quot-can-t-rotate-element-into-...
https://forums.autodesk.com/t5/revit-architecture-forum/rotation-in-any-axis/m-p/3344679/highlight/t...
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
