Host family on 3 walls?
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
humbertolopezholguin
439 Aufrufe, 8 Antworten
Hello all,
Is there a way to host a family, say a counter top, on one wall and have it extend to the adjacent walls so I do not have to realign the ends every time I shift one wall. I am open to different options but would prefer for the process to be automatic.
Also, and less importantly, I have created several families that have different thickness, depth, height, and visibility parameters. Is there a way to edit them in the properties window as opposed to opening the "edit type" window to edit them? i.e. toggle grab bars and accessories on/off in a ADA toilet stall I created.
Thanks in advance.
8 ANTWORTEN 8
Nachricht 2 von 9
@humbertolopezholguin wrote:
Hello all,
Is there a way to host a family, say a counter top, on one wall and have it extend to the adjacent walls.
Are we talking linearly? Why does it matter?
In answer to your second question: make the Parameters INSTANCE kind in the Family.
https://www.cadlinecommunity.co.uk/hc/en-us/articles/201872231-Difference-between-Instance-and-Type-....
Nachricht 3 von 9
I would like to drop shelves, counters, etc, on a wall and have them extend to the left and right until they touch the face of the adjacent walls. So yes, linearly... if I understand your question correctly. I have a work around (drop the family on a wall, manually extend the ends to the walls, add a dim, lock the constraint, and delete the dim) but I am lazy and it would be helpful if I could just drop it in and not worry about doing it manually.
And thank you @barthbradley for the tip. That did it.
Nachricht 4 von 9
That's not hosting related.  Your method is fine.  I could give you some suggestions on how to build a Family that does that, but it would involve a lot of work on your part.   I doubt you want to go there for a countertop.
BTW: if your length is controlled via an Instance Parameter and the countertop is constrained at both ends to a Ref. Plane and the Labeled Dimension is pulled between those end RPs - then you have Shape Handles to drag in the Project to "pull' the ends of the countertop.  That make sense?
...SH*T! The OOTB Countertop does that! Open it and see what I am describing.
Nachricht 5 von 9
als Antwort auf: humbertolopezholguin
Using instance parameters to stretch the family in multiple directions work just fine when the wall corners are 90 degree.
For U-shape / non 90 degree:
- You could use a wall sweep host on 3 walls for the countertop, then place cabinets under it.
- Other ways: 4 point adaptive family, railing, model in place sweep with pick path.
Nachricht 6 von 9
als Antwort auf: ToanDN
@ToanDN wrote:
Other ways: 4 point adaptive family, railing, model in place sweep.
...or make the room narrower.  :zwinkerndes_Gesicht:
Nachricht 7 von 9
@barthbradley, I would definitely be interested if you could point me on the right direction on what I would have to do to automate that process. I bit of work now might save a lot of time later. The project I am working on now has a lot of countertops, shelves, etc. and we are still moving walls around. Thanks.
Nachricht 8 von 9
Why not just align the end to the wall and lock it?
Nachricht 9 von 9
That is the workaround I mentioned. It is just an extra step I would rather not do (I know, I am lazy). But if I would nest objects (electrical, mechanical, furniture, etc.) with different parameters with one click, I would be more than happy to invest the time before hand. Locking constraints works just fine until then.
