Horizontal Shape Handles on Windows
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
877 Aufrufe, 5 Antworten
Hello Autodesk-Community,
is it possible to get horizontal shape handles on windows?
I created a generic window family and set the parameter width and height to instance. I only have the shape handle for the horizontal dimension in my project.
I am working on this family for fast, exact and instance-based as-built-modelling.
Thank you :leicht_lächelndes_Gesicht:
Tags (1)
5 ANTWORTEN 5
Nachricht 2 von 6
Ilic.Andrej
als Antwort auf: Anonymous
For the reference planes that make the handles, verify that the "Is Reference" value is any other than "Not a Reference".
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 6
als Antwort auf: Ilic.Andrej
The value is "weak reference".
I have a similar Problems with doors. There i only have horizontal shape handles and no vertikal shape handles. Is is a "catagory issue"?
Nachricht 4 von 6
Ilic.Andrej
I rly don't know what could be the cause of this. Read this thread:
http://revitelemental.blogspot.rs/2010/06/shape-handles-dragging-grips-and.html
Try that....
Andrej Ilić
MSc Arch
Nachricht 5 von 6
Sahay_R
This is what you need to see in the family -
to see this in the project
All else failing, can you share the problematic family?
Rina Sahay
Revit Architecture Certified Professional
Nachricht 6 von 6
als Antwort auf: Sahay_R
Thanks for your help!
The Problem was the view. You only can Change dimensions with shape handles, when your view is parallel to these axis. My wall wasn´t in a 90° angle, so i only was able to Change the vertikal.
Kind regards!
