Home Screen for Revit
curtisridenour
curtisridenour
This new interface for Revit 2025 is excellent. But I have to click "Autodesk Projects" every time I open up Revit. Is there a way to set this as the default in the INI file or something to have this be the interface displayed every time I open up Revit?
TripleM-Dev.net
I would actually expect it to be saved in the Ini or Registry.
Any change the Ini is readonly or is reset on start of windows
This happens on every Revit open as you state, or only when windows was restarted?
Do other settings kept like recent files and snap settings...
Seems as it does reside in the Revit.Ini: "UseUDAHomeAsDefault"
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-B01A6B07-4FF2-4115-8B61-1274FAF9CC91
- Michel
