Looking for a family or a way to change my door family to have my hollow metal doors wrap around walls i.e. gyp. board walls, or 8" CMU walls. I'm aware my question is rather vague and maybe there's no way, but we have some people on the field not building stuff right because of it.
Any help is appreciated, thank you so much in advance!
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Not sure if you are asking someone to model it or if you are modeling something and need help with it,
There are some OOTB families from the content libraries whch are fairly detailed and can more or less be close to what you are looking for. the below are from the germane Content Library, Quite detailed and highly customizable.
You can down load the library, then edit/translate the parameter name and or change a few values and you are good to go
I think finding a different Door family than what I'm using would be the best solution, however, my question was really is there a feature in Revit that changes them to wrap around, thank you for your answer!
Sorry I missed that part of your question. Its not an OOTB feature, no.
It is how the frame is modeled in the family. It doesn't need to be a 3D element, is can also be a 2D detail components modeled in the same family or nested in. It just needs to be there. So basically it is either you edit/modify the family you have or just use a different family for the time being till you model a new one.
It shouldnt be hard to edit the one you have, if you upload it here I can try to show you how
