I am working on my roof plan, and I can't get rid of these holes. I got this view by setting the view range at 50'.
They aren't there on any other view...
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Are there any shaft in a different phase? Set the phase filter to None and see,
Also, turn on plan regions and see if you have any there.
If you tab-select those holes, what element shows up in the Properties Palette?
It doesn't give me the option of changing the phase filter to none,
How do I turn on plan regions?
I can't select them. When I delete the roof that they run through they disappear... If I move the entire roof they also disappear.
Click on it and you can change.
VG > Anno tab > Plan Region
Use The reveal hidden object and see if there are suspected object(s) that is hidden
That did it, there was something hidden that I couldn't click on. I showed all hidden elements then I was able to click on it and delete it. Thanks!
