is there a way to draw a hole of a certain depth in RC strip footing?
Something like this:
Regards!
Gelöst! Gehe zur Lösung
This can be done with a Generic Model face based family. Create the void shape you need and cut it from the provided object and you should be able to cut the footing.
Perhaps a video would help: Revit 2017 - Cutting a hole in a footing
If you are in the project, use @Anonymous approach by modeling the void and cutting the footing with it using in-place component method. Set your work plane to the top face of the footing.
Thanks, it did the job!
...thought there's something much more faster! ......:-(
There are some basic rules with using voids to cut elements:
- System elements (walls, floors, pads, roofs, strip footing) can be cut by in-place voids and voids in loadable families
- Loadable elements (columns, beams, isolated footing, etc..) can only be cut by voids in face based loadable families
* Exceptions: System face based opening tool can also cut floors, ceilings, roofs, columns and beams, but not walls and footings.
